One thing missing is heat fins.
Flame lockers are sirling cycle engines that suck in hot air then a flap valve covers the intake vent then heat is absorbed and dissipated by the cylinder causing air volume to shrink drawing piston in.
Last one we saw some years ago was brass with fins cut like a motorcycle engine.
You can use the tube above as is just clean up the bore then make a heat sink that fits over the cylinder.
