- May 27, 2016
- 3,469
At $2000, I can see the reason why the folk wanting a reasonable better quality grade grinder will opt to make it a project, or they use available grinders as a kit that they upgrade. That so many and varied belt grinder projects exist, all well displayed on YouTube, probably speaks to the fact there were needs that were not being met, and throw in at a price they would find acceptable.Yes, the Square Wheel belt sander I have was used by my father and me to make knives, back when he was a member of the American Knifemaker's Guild. It got very heavy use. It has the original 1 HP industrial 110/220v motor and had plenty of power to grind metal till it was glowing red hot. Obviously, when dealing with knifemaking steel, you didn't want to get it to cherry red, due to the risk of depleting the carbon in the metal, and work hardening. A water bucket was next to the grinder to dip the steel in to cool it after each couple of passes.
I was tickled pink when he called me to drive 1300 miles to come pick it up. I have a lot of history with that belt sander. It is worth noting the JET version of it now costs over 2000 dollars. It is still considered the gold standard for belt sanders for knife makers.
Here at HM, we get to find out what grinders are being used, what grinders are being aspired to, what grinders would not be considered again, and what kinds are being upgraded/replaced. Just learning about the utility of a glass backplate means that it becomes a feature one starts to look for when perusing advertisements or store offerings. Not that the store exists in UK, but would one expect a feature like that on kit found at Harbor Freight, or similar outlets?
