- Apr 30, 2015
- 11,376
Meir: What type of annular cutter are you planning to use? You might need more than one to make that many holes in 1/2" steel
Mark
Mark
Hi Mark.Meir: What type of annular cutter are you planning to use? You might need more than one to make that many holes in 1/2" steel
Mark
Good to experiment and find what works best for you- as long as the steel is mild it should be ok, a backup drill is a good idea too
Be careful of the sharp chips
thanks Bob. that's a valid point. i'll consider that.Be advised the scale on hot rolled plate is hard and abrasive. You may want to remove the scale at each hole site, or overall, to extend the life of the cutter...............Bob
With all respect it's a WELDING table. If used properly and with regularity it not only will, but should, get the crap beat out of it. It will get spatter, arc burns, water and flux spilled on it, have parts beat into shape on it, clamps stress it, beer bottles broken on it and the occasional disc grinder run over it.
Putting a coat of almost anything will hinder the conductivity of the table.
Putting lip stick on this pig is not only a waste of time it is counter productive...............Bob
