Band Saw Blades-Need your thoughts
I do stock a few different TPI blades. It seems in the past I’ve cut such a wide variety of different size materials itself been worth it. In the past few week’s I’ve cut 6” rounds and 4”square stock. I wouldn’t want to try either with a 10/14 blade
What blade would you use for a 5" piece of steel?
Is there a printed guide for suggested teeth count for a given diameter range, material??
In this case I would use a 4/6 variable tooth blade which is pushing the rule of thumb. The "optimum" number of teeth engaged is supposedly 6 to 10. However, I've never had a problem breaking blades when staying close to the guidelines. I like the variable tooth profile in that it reduces the harmonics and allows the saw to produce a smoother straighter cut. If I didn't have that one in stock and it was a one off, or small volume I would probably use the power hacksaw rather than purchase another blade.
I was buying 14" power hacksaw blades for about $2.00 a copy when they fell out of favor. I have well over 50 in stock from 3TPI to 18TPI. In this case the power hacksaw would be a bit slower than the bandsaw, but the fact that I wouldn't have to spend an additional $45.00 or take an hour out of the day to go pick it up would more than compensate for the additional cutting time.
For some reason I seem to have collected metal cutting saws over the years. I currently have a 350mm (14") Baileigh cold saw, an H175 Startrite horizontal/vertical bandsaw, a 10" Rockwell vertical bandsaw, a W66 Racine power hacksaw, and a Black & Decker 14" chop saw.
ON EDIT: I missed the question about a printed guide. I'm not sure if a table exists. This is something I learned way back when I was working in an experimental design shop. Ellis has a brief guide for blade selection on their website under the "Tooth Selection" (TPI) heading.
Lenox on the band resaw, Morse on the little 4x6 because they are locally stocked.
I'd say you have your bases covered :)
That's an old lathe you got there
The lathe is a 1916 Seneca Falls 9” K model. It was used by my wife’s grandfather for over 45 years in a vending machine company prototype shop.
When he retired it was given to him. When he passed it went to my father in law. When he passed 24 years ago I became the custodian. It’s still in great shape and I use it on a regular basis
Running coolant helps with SS.
Boy, no kidding
I have a coolant pump/tank on this saw but it makes such a mess I don't use it.
The piece of stock got so darn hot I could smell it let alone touch it.
Lessons learned!!
I received the new blade.
Wow, the old one was worn out. No broken teeth. I guess I'm doing something right.
I went through the break in procedure. This blade rocks.
These two pucks are parallel within 004". I'll take that.
If you like the speed and accuracy of a well tuned bandsaw you’ll love a cold saw. They’re roughly twice as fast as a bandsaw and even more accurate. Most manufacturers advertise repeatability within .002”
Might be a nice addition to your shop.
