That's great.To update everyone i have a good looking spindle and bearing from what it looks like. I do have a missing tooth on my small back gear though. That kind of sucks as idk what im going to do with that at the moment. I will get some pictures of the spindle bearings and the gear. I am thinking of taking some mineral spirits and flushing the bearings out.
so in case you are not aware.The felt was black but not hard. Id like to not take the headstock off the bed right now. So i will put something in the holes to drain. Debating on what to do for the bad gear right now. I currently dont have gas for torches to braze material on and dont have gas for the welder. I have a 110 stick welder with some brazing rod i could maybe use. Tonight i will clean up the headstock casting and take the the rest of the stuff that really needs to be cleaned to work.
You can get a gear on fleabay, just turn yours down for a tight slip fit.The felt was black but not hard. Id like to not take the headstock off the bed right now. So i will put something in the holes to drain. Debating on what to do for the bad gear right now. I currently dont have gas for torches to braze material on and dont have gas for the welder. I have a 110 stick welder with some brazing rod i could maybe use. Tonight i will clean up the headstock casting and take the the rest of the stuff that really needs to be cleaned to work.
btw black and not hard means it was probably oiling. If it gets hard or singed it's not oiling.so in case you are not aware.
You have the felt hole
And right at the edge of the bearing is a little weep hole for the oil go drain back into the head.
That's a pretty small hole.
Yea i think it needs a shim. I will find out after i put it back together. I have all 4 clips for the weeps holes and they are all clear.btw black and not hard means it was probably oiling. If it gets hard or singed it's not oiling.
So your original problem was probably solved by your loosening the spindle nut.... and you didn't have 2 problems.
I would braze a new tooth on. Or I might even consider JB Weld, but you would have to wait for it to cure really long time before using it.Yea i think it needs a shim. I will find out after i put it back together. I have all 4 clips for the weeps holes and they are all clear.
@Jim F i saw your post for the back gear. It is an option just not sure if i want to go that route yet. I only have this lathe as well.
