I was drilling into some Aluminum to make some stand offs for my DRO scales. As i was drilling the motor started to bog down and slow down like it was going to stall. Even if i let up. The video i posted still does it without any cutting. I went to the next speed down when i used a parting tool and it didnt do it which is strange as that is a higher cutting pressure? I am not in back gear and the bull pin is engaged to the cone pulley. Im hoping maybe the belt was a little loose as well? It is a new belt so it could be stretching?
View attachment FullSizeRender.MOV
I have felt kits to the whole lathe and i havent taken the headstock apart yet. The left bearing was a warmer then the right bearing. I have oil in the cups but i know the right side soaks in much more then the left side.
