I oil the countershaft every time. I have not check it to see if it is tight or not and i do have a broken oil cup on the one side. Id like to get some gravity fed oilers for the countershaft. Can only do so much at once though right! Lol
well just try and figure out where the problem is..I oil the countershaft every time. I have not check it to see if it is tight or not and i do have a broken oil cup on the one side. Id like to get some gravity fed oilers for the countershaft. Can only do so much at once though right! Lol
Sounds like you need to make a shim.. Not hard, the hard part is getting it in there. The way the shims are, they are stuck together and you peel them off.. A nice design. I needed an in between size and made my own. That's a good find... Now is it heat related because its not getting oil, or is it just too tight???Ok so update. I check it again. The lead screw is loose and smooth. I put the lead screw in idle position and it still does it. I ran it until it happened and the check all shafts for mobility and the countershaft motor and spindle seem to be fine. I did not loosen the take up collar yet but someone said to loosen the spindle bolts up top a 1/4 turn when it does it. Bingo it goes back to normal when i loosen the bolt a 1/4 turn. I am guessing that left bearing in the cast is tight or not getting enough oil.
Thats is where i am unsure. I feel like i hardly put oil in that cup and the cup on the right just drinks it up. I can make a shim to get put in there but my question is how do you find how much shim you need. I think i am still going to take the headstock apart and service it bc that is one more part on the lathe that has been taken apart and cleaned. I was thinking maybe an extra 3 thou for the shim would be ok?Sounds like you need to make a shim.. Not hard, the hard part is getting it in there. The way the shims are, they are stuck together and you peel them off.. A nice design. I needed an in between size and made my own. That's a good find... Now is it heat related because its not getting oil, or is it just too tight???
