4
4GSR
Forum Guest
Register Today
Ok, on the cross feed screw where it mounts to the face of the base. That mount must be removed and the mounting holes will probably have to be elongated to allow for proper alignment with the nut on the saddle. You usually have to "play" with this adjustment until you get it in the right place with minimum binding.
Let us know how you make out or if you need more guidance. Ken
