- Dec 30, 2011
- 214
I'd be surprised if the commutator wore down; treadmills don't often get used that much. Most that I've seen, were abandoned when their owners lost enthusiasm.
As people have said, armature. Armatures wear down, diminish in diameter, the mica between poles is now equal to the diameter of the copper. The copper is burned. Armatures can be turned down to provide a clean even surface and then the mica cut to below the level of the copper.
This is a common problem with DC motors but most motors are scrapped instead of repaired.
Vlad
I'm not sure how a variable speed motor would solve the bogging down problem. The problem is not enough torque to handle the load.Has anybody tried a treadmill motor conversion to a tablesaw?? The variable speed thing seems like it would solve the biggest problem with table saws: bogging down under load ...
Opens will usually be at the commutator connection, and might be fixable.some pairs do seem to be open
Open windings will definitely cause sparking . A dead sure test is to rotate the armature to different positions. The motor will not start if on open winding.
Regarding fixing breaks at the commutator, I have successfully repaired open windings on drills and on a Dremel. What I did was to first find the break, usually with a magnifier. Then I teased the broken wire out of the varnish or epoxy it was usually embedded in. Next, I scraped some of the insulation off so I could solder a short stub on. Then, the commutator copper had to be cleaned to allow soldering the stub to the commutator. Finally, I checked the winding for continuity and rebedded the repair with epoxy.
Bob
