ok ... so ... newbie here ... just starting out: I ultimately want to use the motor out of my wife's treadmill to power a drill press ... I know, I know ... first I have to convince her that I can't fix it. It was doing fine for quite awhile [as a treadmill, at least], then it [sort of suddenly] started to arc in the brush area, smell "electrical", lose power, and generally run real slow as well as poorly [but nothing was spilled on it or anything like that]. So I'm trying to diagnose it while it's still in the treadmill: motor controller is MC60, motor is a 2.5 HP McMillan, treadmill is a ProForm [Sears, I think ... It was given to us]. I popped off the end cap and looked at the brushes: They seem fine ... not even close to worn or too short. Springs and caps seem fine, too. Yet, when I reassemble it, it still seems like too much spark and too much smell ... I never had the covers off and looked at it while it was running OK, so I don't really have anything to compare to.
So I guess my question is [vague, I know]: Should I be looking at the MC60, or the Power Board, or the motor itself?? If I need parts, I would rather get parts for a drill press than parts for a treadmill ... nobody can help me with that battle, so, all I'm really asking for is maybe a process of elimination to sort of help me start to know where to look for the culprit ... if i have to admit defeat on fixing the treadmill: I can then start work on the drill press [but maybey not with this treadmill if it needs new boards and a new motor].
Thanks for any possible help or encouragement ...
