- Jan 2, 2019
- 6,545
Sorry, just re-read your post. I thought you already had a wood cutting saw and were trying to make that work.
Agree with the coldsaw comment above. I'll be letting my horizontal bandsaw go when I get my little vertical set up since I have a small coldsaw for cutting bar stock. The coldsaw is just freaking amazing and all the much better that it was free. I think it's tough getting something that will do double duty here, solid bar stock can easily (but not accurately) be cut with a 4" angle grinder. Horizontal saws also do well with this but are pretty limited when turned vertical.
If most of your bar is fairly small then switching to a capable vertical saw for pattern type work might be fine if you're just cutting solid pieces to length for working on the lathe or mill and don't mind the mess and noise of abrasive cutting.
I'll let others comment on portaband saws since I don't currently own one.
Like I said, I might not be that helpful here....
John
John
