- Mar 19, 2014
- 2,681
I would save your money. It’s just another toy. I have been eye balling the tool height for 50 years and NEVER had a problem. When I face, I do take the time to totally remove that tit…Dave.
The level vial is comparing to an earth reference so if the lathe is tilted front to back, the vial will not center the bit ion the spindle axis. If you have leveled your lathe then fine, if not, I would calibrate the tool by checking a known good setup. (Actually, I would check it against a known good setup anyway because there is no guarantee that the tool is accurate out of the box)The lathe does not need to be level for this tool to work. It does not need it. The vial level is only to let you know when you have hit dead center between the cutter and the work piece. It is not used as a level per-say. It just lets you know when you are straight.
"Billy G"
How would you use it on a ship then?The lathe does not need to be level for this tool to work. It does not need it. The vial level is only to let you know when you have hit dead center between the cutter and the work piece. It is not used as a level per-say. It just lets you know when you are straight.
"Billy G"
You would need to find a ship that is perpendicular to gravity .How would you use it on a ship then?
