- Dec 18, 2019
- 6,539
I have a small combo lathe/mill.what kind of mill?
I think most every mill will handle 4 clamps. Even my small Clausing 8520..
You are going to a 6" so you must have a bigger mill than mine.
That's pretty much what I was working towards.Make something like this to hold down the vise. I made these last January. Don't use socket head screws, they fill full of swarf, use a hex head instead. Make sure the screws aren't too long, or it could damage your table. For that matter, get or make tee nuts that a bolt cannot thread through.
Made the hold downs out of A36 1x1 stock. Took me longer to figure out what to do and draw it, then to actually make them. One can get tee-nuts already peened, or punch them, just like you said.@WobblyHand that's the solution.. easy peasy.
As far as T nuts, you can either partially tap using a gun tap and not go all the way
Or I just take a punch and peen the last thread so it can't go any further. I am assured of the number of threads that way.
Why dedicated mount points? They are incredibly inflexible and effectively permanent. If you miss drill, you have pooched your table. If you screwed up your calculations, you have pooched the table. If you need a different setup at an 1/8" offset, you have pooched the table. Effectively impossible to reverse. Please don't drill the table, it's almost never necessary. Just my humble opinion.That's pretty much what I was working towards.
I've already had to make a couple T-bolts because the Smithy comes with really soft ones.
The big difference between what I want to do and what you've done is I want to have dedicated mount points. Hence the drilled holes.
I could do that but it would be with great sacrifice. Every time I put the vise on I would have to remove the lathe tail stock and, frankly, it's a PIA to get back on.Can your machining technique support rotating the vise 90 degrees? So the vise handle is over the edge of the table, rather than over the table itself? You can drill if you want, but usually there's a way to avoid it.
