- Mar 3, 2017
- 745
Not entirely correct. Some aluminium alloys are found but aluminium on it's own is quite rare. You are probably refering to bauxite which is plentiful.
...contributes to lesions in the brain causing alzheimers...
Here is some more info:
https://www.atsdr.cdc.gov/phs/phs.asp?id=1076&tid=34
In referring to '8 percent', I meant that eight percent, by weight, of the Earth's crust
is aluminum atoms. They aren't atoms in native pure metal, but in other compounds.
Washita sharpening stones are nearly pure aluminum oxide, bauxite is just
the most economical ore for making pure metal.
The electron microprobes of Alzheimers' plaques that showed aluminum content, were
not finding metal, just atoms. The original findings have been traced to tissue preparation
materials, so the aluminum is not a likely culprit in the malady. It certainly is not
a known toxin.
The CDC link is full of guarded language, but one statement is clear:
"You cannot avoid exposure to aluminum because it is so common and widespread in the environment."
