... that is, using two phases (hot lines), then the switch must be double pole.
I think it is split-phase ... single phase with neutral grounded ... not two phase, and you are correct, it will require a double pole switch.
I just have mine wired to it's own dedicated breaker. I use a number of my breakers as switches for lighting and service disconnects.
You are correct in that common 200+ volt service isn't officially called "two phase", it is called "single phase" but it does in fact use two phases and no neutral. One phase and a neutral is also commonly called "single phase" or "split phase" yielding typical 115-125 volt service. Then of course there is "three phase" which uses all 3 phases....All of which is a common source of confusion for many trying to understand AC electricity.
I just picked up a really nice Porter Cable 60 gal compressor for the shop/garage. In the owners manual it states that there should be an on/off switch between the main power and the pressure switch. I've never heard of or seen this before. It's a 3.7 HP 240v single phase 17.2 FLA.
Anyone heard of this? What should I use for the switch? It actually says it will void the warranty by not having one.
Thanks all.[/
Code, local disconnect within sight of the device, does not require lockout/tagout protocol for maintenance.
Technically, you're not supposed to use a breaker for a disconnect except for lighting if its rated to do so (HD). I've done the same thing with my compressor for years until I finally hard wired it to a 20a circuit with wall switch.
Electricians often refer to the two hot lines ("L1" and "L2") of a single-phase 240VAC center tap grounded service as phases. They're wrong (but there's no point in trying to tell them so). A two phase service would have two pairs of wires with their voltages 90 degrees out of phase.
