I just cant visualize this?With square, rubber band some small pieces on the end of your work and indicate inside those (DTI). Much improved.
I don't follow your thought either. What do you mean indicate on the inside?With square, rubber band some small pieces on the end of your work and indicate inside those (DTI). Much improved.
If you use a rubber band to hold 4 pieces of flat stock on your square material, you've essentially created a piece of hollow square tubing. You can indicate on the inside edges with a Dial Test Indicator (DTI) without catching a corner and damaging your indicator.I don't follow your thought either. What do you mean indicate on the inside?
