Hi Folks,
Occasionally the cross feed power advance kicks in when I do not want it to. When it does, a part is ruined in a hurry. I have seen several pictures and descriptions on how to adjust the clutch but none are exactly like my lathe. On my machine there is a large setscrew on the left side of both the longitudinal carriage feed lever and the cross slide feed lever. That screw seems to be only a cover. Underneath is a much smaller set screw which seems to be the means of adjusting the clutch. But turning the small set screw seems to make no difference in where the lever engages the clutch and starts the feed. Should I tighten or loosen the set screw to help prevent the cross slide from engaging when I do not want it to do so?
I would take a picture, but it's really hard to get a camera in the right position.
Any ideas?
Any ideas?
