Ok.. Got my new gears in hand and started into tearing it down. I thought I could do it all from the bottom but can't get good purchase on the lead screw to loosen the nut on top of the gear.
So I took off the table and cross slide and lead screws to get a socket on top of the gear. This is what I see. It has been thoroughly peened. What is the best way to hold the OD of the leadscrew and use an impact or rachet to loosen the nut?
The knee is still on the mill. I'd really rather not take it off. I don't have a lot of that kind of help to get it all back on.
I thought of milling some grooves in wood blocks and clamp it that way, sort of like a rifle action in a vice. It's pretty smooth and I doubt my strap wrench will hold it.
Is there a trick?
Thanks
Is there a trick?
Thanks
