- Feb 19, 2021
- 19
I was looking to purchase a mini knee mill mill and I'm having trouble deciding between the Harbor Freight 40939 6x26 or the Grizzly G0678 8x30. The Harbor freight is $1850 plus shipping and tax, while I found the Grizzly for $4149 plus $299 shipping from US Tool Depot. Is it worth $2300 to go with the Grizzly for the larger size, VFD, 3 phase motor, one shot lube, and the (supposedly) made in Taiwan quality? The 6x26 would probably be big enough for what I want to work on, but I'm afraid of ending up with something I want to work on that's too small for the 6x26. They both take up about the same space (once the 6x26 is on a stand). I found a VFD and 3 phase motor on Amazon for $220 and $260 (not including switches, wiring, tachometer, etc...), respectively, but I can live with swapping belts initially. I figure a stand would cost about $50-100 in materials, plus the materials for a riser block and head spacer would cost around $200. I'm afraid with the riser block, I wouldn't be able to get the table close enough to the spindle to work on flat pieces without using the quill (I'm a machinist and I was taught the quill is for drilling and boring only) or placing the piece on 123 blocks or similar (I used to run a surface grinder at a tool and die shop and have become paranoid about making sure the work is fully supported). The only manual mills I've run are Bridgeports and clones, and bigger, and while I'd love to have a Bridgeport sized mill, I don't have the space or capabilities to move a 2000lbs mill. Plus all the used ones in my neck of the woods are either around $3500-4000 in rough condition without tooling or out of my price range. A Clausing 8520 popped up on CG but was sold within 24 hours. I've heard horror stories about the Harbor Freight, voids in the castings including in the ways, but there seems to be quite a few people who've been satisfied with them. I've also heard horror stories about Grizzlys, including the Taiwanese made ones, with warped or twisted ways, ways ground out of square, ways ground concave or convex, poor way surface finish, etc.
I was also looking at purchasing a lathe. I pretty much settled on the Grizzly G4003 but I found this Birmingham YCL-1236-GH that comes with a stand (but it looks like the flimsy G4003 stand Grizzly sells) but doesn't come with a drill chuck, live center, or QCTP. Chucks and centers are pretty cheap, but not QCTPs. I haven't found much on Birmingham lathes, but what I have seems positive, at least for their larger lathes.
