L
Lordbeezer
Forum Guest
Register Today
Grounded a wire in j25..got rid of e stop code.still won't go into maintenance mode but can pick a program and set speed.and it works...motor and gear reduction box move around because of how its mounted.will fix.had to remove screwdriver in stop switch to open the circuit.still have 3 open terminals in j25..1 has power..others??? Any ideas? Thanks for your time and help..Phil ..I'm thinking as you stated ulma doctor.j25 is the key..
