The handle on my wood stove has been getting looser and looser over time. There is an adjustment to compensate but that is all used up. So I pulled the handle from the stove and seen that the shaft on the handle was fine but the block it passes through is badly worn and so is the wedge shaped latch. The latch is made of steel but the block is made of brass and I don't have any. So I figured I would just order the part. Dealer tells me I have to buy the whole assembly and it comes with the block the latch and the handle. Cost ....... $85 plus taxes = $95. No way I'm paying that ......... I have a lathe and a mill. So I pull the assembly apart and take measurements of the block, shaft and latch.
I decided to just weld some steel onto the worn latch and just make a new block out of aluminum scraps that I previously melted down in my forge. If the aluminum isn't strong enough I guess I will make a new one out of steel or see if I can find some brass somewhere.
Here is a pic pic of the stock handle assembly on the stove.
The brass block. There sure isn't much meat left on the shaft opening nor is there much on either side of the screw holes that hold it onto the door. I should have noticed that before I started making the new one. The face in front is on a 5* angle to the rest of the block, to allow for the angle of the door edge, where it mounts.
Here is a pic of the installed new block. I should have taken pics of the process but forgot. I should've also rounded the edges but this is in my shop so I'm the only one that will see it. If it was in the house I would have to make it nicer for the wife.
I also finished making and mounting the drawer faces on my lathe stand. I decided not to paint them because the natural grain of the wood is much nicer to look at. Well for now anyways, until I get my grubby hands all over them. I like the way the stand and drawers turned out and I really like having all the lathe tools, measuring devices, etc. at hand. I like it so much I'll probably end up making something similar for the new lathe that's on it's way and for the mill / drill, just so I have all my tools handy instead of laying all over the floor and a bench that's 20 ft away.
