- Jul 10, 2013
- 1,189
This was not enough of a justification to buy a lathe, too? Just kidding. That was a clever way on how you made the fix and it looks better, too.
That makes sense. And while I'm sure it wasn't a 60 degree tip (I just guessed at the angle since it wasn't critical and it was off the poorly designed scale on my Logan compound) I'm sure what I had before I filed it round would have worked for such use. For that matter I could make up a simple "reverse center" for that purpose. Infrequent use, reasonably tough geometry (not like the point on a normal center), and not a significant load for this kind of thing, so even mild steel would probably hold up fairly well.Yes, it does. For brass or bronze, I usually chuck short and turn a 60° point on a bit of waste, and just chuck on a broken tap shank that has a grinding center hole in it in the tailstock. I run it like a dead center, with lube, then cut it off when I an finished.
I love the simplicity of that statement.learning has occurred.
