- Aug 19, 2013
- 764
The Enco corner notcher arrived this week and it was slated to go into the spot the Lars-Gorton tool grinder occupies.
I'm short on space so almost everything is on rollers or skates for access. The tool grinder lived on the back side of the rollaround cart the drill presses are on - and recently every time I've had to move it there were complaints from the casters. With everything loaded on it the cart weighs about 450 pounds and it can be a beast to move if there's a problem. On closer look the casters were coming loose from the cart so this simple project of swapping the grinder for the notcher took on an entirely new dimension.
I rolled out the drill press/grinder table, and slid the grinder onto another rollaround in preparation for moving it out and/or selling it. Next I set up the engine hoist and lifted the two drill presses off the table and onto the floor, then removed all the crap from under the table and flipped it over.
I whacked off a couple of pieces of 1/4" x 6" bar stock and punched holes into it to attach the casters more firmly, then screwed the caster units back onto the bottom of the cart framework. You can sort of see the bottom of the cart in the first picture - This is the messiest the shop has been of a while.
Photo 2 is the front of the rollaround once I got everything re-positioned, photo 3 is the rear view of the cart showing the notcher in position.
And the rollaround cart rolls again!! Woo Hoo!
Stu
View attachment 126115 View attachment 126118 View attachment 126119
Nice concept gr8legs. Is it stable on casters when using the notcher ?
I'm thinking of something like this for my Grizzley 6"notcher & my Beverly B2 throatless shear. Then again, my "round tuit" list will already outlive me.
