Resurrected an OLD motor and made ?
Well, I've been working on this project for a few days now. A friend gave me
an old electric motor which I didn't end up using for anything. It's been laying
around in the shop for months. It is a Brushed AC 110-220v motor with brass
bushings, the kind with a ring on the shaft dipping into the oil reservoir and
some real brass Gits oilers. It was really dirty, that took a day to get it
cleaned up. Then I noticed the armature had been rubbing on the field
assembly, a sure clue that the bearings might be worn. The motor shaft side
was pretty loose so I removed it from the case and squeezed it a bit in my 4 jaw
lathe chuck. Not much play now. After cleaning up the brushes and armature,
it ran just fine. Well it ran fine but the output shaft was out of true by 20 thousandths
or so. A few good hits with a big hammer and it was straight enough to be
undetectable. Also a 12 inch wire wheel was given me by a friend so made an
arbor for that. As luck would have it I found a truck axle shaft and a matching
rim so made a base using that. The hard part was cutting off the axle. It was
very hard material! The HSS cutoff just made a few turns and was dull. On to
the carbide cutter... not much luck there either, it cut hair fine blue in color chips
and immediately the leading edge of the cutter gave way. I had to grind it in half
with my angle grinder. Finally it all came together with a bit of band saw work
and welding. I think I will put this outfit in an outbuilding and use it there
since it is a messy tool leaving rust residue all over the place. I think some heavy
gloves will be in order and maybe some rocks piled into the wheel rim for stability.
I still have to clean up and paint the stand but for the most part it's complete.
