- Feb 25, 2021
- 3,146
I understand that the power utility does their own trenching to the meter. I’m actually waiting for our local utility to trench to a new 400a meter, multicolored flags all over the yard.A lot of electric companies won't install into someone else's trench. They are responsible for the feed to the meter, so they do the digging.
That side-track started because to me 200’ - 300’ between buildings wouldn’t justify a separate meter and the long-term ongoing monthly base charge usually associated (depending on the local rate structure) with each meter. Even at current price of nearly $5/ft for suitable cable, those economics do change if you rent a trencher for a couple hundred bucks and do it yourself, or prefer to pay a contractor to deal with the feeder line to an outbuilding. @FliesLikeABrick strikes me as a DIY’er, but the separate meter came with the property.
In my case, with a 400amp meter, a solar system wouldn’t be a choice between serving house, or shop. Regardless where it was installed it would serve both. Backup generator gets to be a more complicated as I’m using dual 200a service disconnects, so I believe that would essentially require two transfer switches and two generators to cover both, although I haven’t looked into details for that config.
