- Jul 14, 2017
- 2,450
It's been sometime, since i've done it on a peugeot 207, but camshaft locking tool is locking them on the squares, my tool fit very loosely. Also that was a dot and a groove on the intake sprocket at the vvt camshaft. I had the loose end with vice grips turn the camshafts to get them centered in the timing tool because they want to turn from the valve spring pressure. then i tighten all three bolts by hand, unlock the engine, put my own marks, thengion the chain then turn the engine over by had two revolution and it has moved. I loosen the bolts and made correction then tighten them and checked it again, it had moved again, made one more correction on the crank bolt, checked it and was good, then i tighten to spec all the bolts.
