Wife calls me today and the “check engine” light is on she says.
I instantly awitch into aww F!!!! Mode.
My truck is laid up and needs a new front shock (warranty work), the van is still at the body shop and needs a #2 cyl misfire chased down, my mustang is off the road (has been for years) and the corvette has antique plates and can’t be used to drive to work.
5 cars, 2 drivers in the household and they’re all broken!!!! Arrgggghhhh!!!!!
She gets home and when I check, its not actually the check engine light. The mini has a “service“ icon which looks like a car on a lift. Hook up the scanner and the car says the rear brake pads are worn.
They actually have a sensor on it, a brake pad.
WTF?
Stupid BMW. Lets put a sensor in the harshest, most dirty spot on the car. Jebus.
Pads look to have a decent amount of meat left on them from peeking in through the wheel. But the sensor is on the inside pad, which you can’t see. So the inside pad might be at wear limits. It a double piston caliper, but it wouldn’t be the first time I’ve seen one pad wear out faster than the other, even with a double acting caliper.
One of the rotors has a fairly deep score on it as well. On the outside surface, so its something that has gotten caught (piece of gravel, etc) and marked it.
I’m just going to buy pads and rotors (only about 200 bucks) and change ‘em out this weekend.
Then its start working on the van (body shop said it will be done by cob today) to fix that #2 misfire. the mil was on when we dropped it off but the body shop cleared it and didn’t do a peint out, so I have to wait for it to come on again to confirm I need to change out the rockers (fairly common fault on the pentastar 3.6 engine).
Never rains…it pours….
