- Sep 24, 2014
- 926
It is a one way container nad has 4 1/2 years CSC certification so I expect it to hold together for at least that long. It production date was 6 months ago so it's like new. I'll still get up on the roof and ensure there is no rust and do touch-ups if necessary to keep it in shape.
Here in Norway that kind of insulation is expensive. The styro is the cheapest I found. I am not settled on what to use on the floor but I like the idea of T&G and epoxy. As far as I know it already has marine grade ply flooring however I want a way to strap the machines down so adding a couple extra layers would be a great way to add thickness so I can screw the machines down.
Paul.
You could try coating the roof and sides with elastomeric paint. It adhears very well and will flex with the metal as it expands and contracts. Prime any bare metal with rust inhibiting primer then coat with the elastomeric coating. You can even have them tinted to the color you would like.
There should be 3/4" plywood floor the additional 1-1/2" would allow for 2" of embedment of the lag bolts which should hold the equipment down pretty well.
If you have not priced the spray foam you should. I was surprised to find that it was only 20% more than standard batt insulation here in the states.
