1965 Heavy 10 Rebuild
Hey Guys -
Not ready yet (been too busy making Woodworking Presents)...but have made more progress. Here is the lathe as she sits now. Merry Christmas to the South Bend Crowd!
IMG_0148.jpg IMG_0149.jpg IMG_0150.jpg IMG_0155.jpg IMG_0157.jpg IMG_0160.jpg IMG_0162.jpg
Two of the four Cap Shims were piecemeal -- other two original SB brass @ 0.015". The expanders were in their PROPER Place upon inspection -- but somewhere down the line the rear sleeve bushing did not have the expanders installed properly (i.e. -- smashed down on top). Machine did run cool before I tore it down - spindle nicely turned by hand - so it should be okay after I clean up a few burrs.
IMG_0187.jpg IMG_0188.jpg IMG_0189.jpg IMG_0190.jpg IMG_0200.jpg IMG_0191.jpg IMG_0192.jpg IMG_0194.jpg IMG_0196.jpg IMG_0197.jpg
Have you ever gone back and looked at your thread to see how far you have really come? I just re read yours, very cool indeed. I did re read mine also the other day, wow it was rusty! It's pretty fun to read a guys restore from start to finish and watch the transformation. Great work my friend, she's looking good.
Greg
Happy New Years Day 2013!
Assembly continues a bit at a time (and I do mean just a bit...).
Rear Caps have 0.018" shims to create just enough lift clearance of 0.0008". I filed away the mushrooming imprints that were on the rear bearing. The expanders look like they were installed on top of the bearing at one time - instead of sliding in the dovetail way. Both expanders are working their magic though -- tightening down the Bearing Caps puts a clamp on the spindle, but tightening (pulling up) the expander key creates clearance as they should. Notice how far up the rear expander rides up and nearly through the rear bearing!! One cannot see how the front expander is working, but it was in much better shape and I barely had to file it -- so my guess is the expander is better mated to the bearing gap than it is in the rear.
Front caps have 0.015" shims, but this has too much clearance at 0.002"-- so I'll adjust. I've run the machine a bit to get a feel for how things are going. Very quiet and just the click-click of the belt hitting the Cone Pulleys....
Added some extension brass sleeves to the lower spindle drainage holes - to allow a clean(er) way to drain/flush the spindle oil.
IMG_6144.jpg IMG_6146.jpg IMG_6148.jpg IMG_6368.jpg IMG_6369.jpg IMG_6372.jpg IMG_6375.jpg IMG_6376.jpg IMG_6377.jpg
Assembly continues a bit at a time (and I do mean just a bit...). Rear Caps have 0.018" shims to create just enough lift clearance of 0.0008". Front caps have 0.015" shims, but this has too much clearance at 0.002"-- so I'll adjust. I've run the machine a bit to get a feel for how things are going. Very quiet and just the click-click of the belt hitting the Cone Pulleys....
Awesome progress, great tip on the oil reservoir drain tubes, when I change my oil I'm gonna steal your idea!
You keep me going Greg!! Thanks for the encouragement!!
Funny! I am a little jelous though, I really want to get mine fired up too, great to see yours spinnin! I am at the point where I need a vfd to get mine completed, made a phone call yesterday but with the holiday no one was there. I'm so close. You encourage me too!
Here are a bunch of photos: removal of spindle, reconditioning of the sleeve bearings with some filing, fitting, etc. Re-installation of spindle, headstock, etc...
Kind of backward as these should have been added earlier..... Oh well, you guys get the idea......
IMG_5369.jpg IMG_5371.jpg IMG_5373.jpg IMG_5374.jpg IMG_5375.jpg IMG_5372.jpg IMG_6119.jpg IMG_6121.jpg IMG_6123.jpg IMG_6124.jpg IMG_6126.jpg IMG_6129.jpg IMG_6131.jpg IMG_6132.jpg IMG_6134.jpg IMG_6139.jpg
Greg -
Those guys at FactoryMation are very nice. I will have to tackle the "right" way to wire the machine later. Now, I just use "quick connects" from Lowes for testing. I'm using an older TECO FM50 - but certainly adequate. From what I know, the Motor is a direct connect to the VFD, then later.... all the start, stop, rev, fwd, Potentiometer controls go directly to the relays on the VFD -- and the VFD will handle it. It is great having 3 ph motors run off of the VFD!
