    Dismiss Notice
1018 cold rolled lathe chuck key
Discussion in 'QUESTIONS & ANSWERS (Get Help Fast Here!)' started by umahunter, Apr 20, 2017.
  1. umahunter
    umahunter United States Active User Active Member
    88
    28
    City:
    yuma
    State:
    Arizona
    -Return to Top-
    Was gonna make up a extra chuck key outta some spare cold rolled was wondering if heating up to red hot then oil quenching would add some durability any thoughts? ??
  2. dulltool17
    dulltool17 United States Active User Active Member
    98
    28
    City:
    Weaverville
    State:
    North Carolina
    -Return to Top-
    Nope. Not enough Carbon.
    You could case harden, though.
    scwhite likes this.
  3. scwhite
    scwhite United States Active Member Active Member
    210
    43
    City:
    Shreveport
    State:
    Louisiana
    -Return to Top-
    Not enough carbon
    You will be better off to go to a steel supplier and order you some 4140 and make you one
    You can buy it 29 to 30 RC . It will machine easy enough . And is still hard enough .
    Or just go it tractor Supply and buy a Grade 8
    Bolt . Machine you one out of that .
  4. umahunter
    88
    28
    City:
    yuma
    State:
    Arizona
    -Return to Top-
    Oh good idea I've got some grade eights I can probably use
    scwhite likes this.
  5. scwhite
    210
    43
    City:
    Shreveport
    State:
    Louisiana
    -Return to Top-
    Get one big enough to drill a hole through it for the T- handle
  6. Tozguy
    Tozguy Active User H-M Supporter-Premium
    699
    113
    City:
    Drummondville
    State:
    Province du Quebec
    -Return to Top-
    I have been using some key stock because it has a very good fit and nice square corners. It is standing up well but then I don't torque my chucks or D1-4 cams all that hard. The round corners and loose fit of the OEM chuck key were too sloppy for my liking.
  7. scwhite
    210
    43
    City:
    Shreveport
    State:
    Louisiana
    -Return to Top-
    Yes yes should not be to hard to make
  8. Tozguy
    699
    113
    City:
    Drummondville
    State:
    Province du Quebec
    -Return to Top-
  9. scwhite
    210
    43
    City:
    Shreveport
    State:
    Louisiana
    -Return to Top-
    Yep I have used a 3/8 drive extension to
    Works good
    darkzero likes this.
  10. darkzero
    darkzero Global Moderator Staff Member H-M Supporter-Premium
    1,212
    113
    USA
    City:
    Los Angeles
    State:
    California
    -Return to Top-
    I used to do the same on the cam locks for my lathe. But on my lathe the came locks are 10mm square & 3/8" extension is pretty loose. I now use a 10mm drain plug socket. I prefer to use a ratchet & extension over the stock chuck type key.
    Tozguy and scwhite like this.
  11. umahunter
    88
    28
    City:
    yuma
    State:
    Arizona
    -Return to Top-
    A ratchet fits my scroll chuck but the 4 jaw are a smaller square
  12. Tozguy
    699
    113
    City:
    Drummondville
    State:
    Province du Quebec
    -Return to Top-
    This is what happens to a cam lock if you use a poor fitting wrench
    4gsr and darkzero like this.
  13. darkzero
    1,212
    113
    USA
    City:
    Los Angeles
    State:
    California
    -Return to Top-
    Ouch! That's what I was afraid of happeneing when I was using the 3/8" ratchet extension on my cam locks. I didn't imagine it could get that bad though. I'm glad I switched out to using the proper size 10mm square drain plug socket. Thanks for sharing!
    To clarify, I stated earlier that I didn't like using the stock chuck type key that came with my lathe for the cam locks. Nothing against using that type of key, I just didn't like the one that came with my lathe. I was too lazy to make a new better key & is why I use what I use but I like it.
  14. umahunter
    88
    28
    City:
    yuma
    State:
    Arizona
    -Return to Top-
    Ok is there a formula to figure out what size circle I need to come out with a square the right size I thought I mesured right but I came out way undersized once I milled down a square with square corners I must have mesure wrong some how ???
  15. Tozguy
    699
    113
    City:
    Drummondville
    State:
    Province du Quebec
    -Return to Top-
    Uma, I would look at the square as two right angled triangles joined along their hypotenuses.
    Measure the width of the socket and use 45 deg. trig functions to calculate the hypotenuse.
    If you measured the socket diagonally there is a chance of coming out too small when the inside corners are rounded.
  16. Tozguy
    699
    113
    City:
    Drummondville
    State:
    Province du Quebec
    -Return to Top-
    DZ, ever since I mangled a cam lock I have been using a better fitting softer wrench. Granted it may have been a defective cam lock (too soft) and lack of experience on my part but I feel better using a tool that should give before the cam lock does. Key stock seems to fit the bill perfectly.
  17. bobshobby
    bobshobby Australia H-M Supporter - Premium Content H-M Supporter-Premium
    186
    43
    City:
    Adelaide, South Australia.
    State:
    Outside US / Canada
    -Return to Top-
    scwhite likes this.
  18. Jonno_G
    Jonno_G Australia Iron Registered Member
    5
    3
    City:
    Mole Creek
    State:
    Outside US / Canada
    -Return to Top-
    Yes, there is.
    If you know your dimension across the flats (say 10mm for instance) then Pythagoras theorem (a^2 + b^2 = c^2) tells you that your diagonal will be 14.14mm, so you need to start with at least 15mm round stock to get a 10mm square.
    Cheers,... Jon.
    Sent from my Lenovo YT3-X50F using Tapatalk
  19. T Bredehoft
    T Bredehoft Active User H-M Supporter-Premium
    1,196
    113
    Central Ohio
    City:
    St. Louisville
    State:
    Ohio
    -Return to Top-
    The diagonal of a square is 1.414 times the side. The side of a square is .707 times the diagonal. These numbers have been in my head for over 30 years.
    4gsr likes this.
  20. Tozguy
    699
    113
    City:
    Drummondville
    State:
    Province du Quebec
    -Return to Top-
    I can't do that, my head is round.
    4gsr likes this.
  21. RCWorks
    RCWorks United States 5 Star Possum Chef Active Member
    30
    28
    At home
    City:
    Anadarko
    State:
    Oklahoma
    -Return to Top-
    I'd ask Tom Lipton at Ox Tool Co.
  22. umahunter
    88
    28
    City:
    yuma
    State:
    Arizona
    -Return to Top-
    So I need to make a wrench with side that are .3125 and mesures on the diagonal .4200 but the corners aren't perfectly square so the diagonal might not be totally accurate
  23. umahunter
    88
    28
    City:
    yuma
    State:
    Arizona
    -Return to Top-
    Mm 7.98 sides and 10.48 diagonal
  24. Catcam
    Catcam Australia Steel Registered Member
    10
    3
    City:
    Parramatta
    State:
    Outside US / Canada
    -Return to Top-
    Hi,
    to get the circle diameter you need to get a certain square machined out of it, simply divide the diameter by the square root of 2 (1.414) gives the perfect size, but if you don't mind a chamfer on the corners you can get a bigger square out of the round shaft.
    Alternatively instead of dividing by 1.414 multiply the diameter by its reciprocal, that is multiply by 0.7071 to give the same answer.
    works for any circle to give the included square.
    Lgotcher and scwhite like this.
  25. bfd
    bfd United States H-M Supporter - Premium Content H-M Supporter-Premium
    153
    43
    City:
    nipomo
    State:
    California
    -Return to Top-
    you don't want to have too sharp of corners on your key. the socket may not have good sharp corners and the key will not fit bill
  26. umahunter
    88
    28
    City:
    yuma
    State:
    Arizona
    -Return to Top-
    Well I got a chance to make a body had to stop and make a vise clamp to use got me to thinking should I use regular cold rolled for a handle or should that be hardened aswell 20170507_022854.jpg
  27. darkzero
    1,212
    113
    USA
    City:
    Los Angeles
    State:
    California
    -Return to Top-
    Handle doesn't need to be hardened, don't even need to harden the entire body either, just the square end will be perfectly fine.
  28. umahunter
    88
    28
    City:
    yuma
    State:
    Arizona
    -Return to Top-
    20170511_140317.jpg 20170511_140310.jpg Finished I used a 5/8 grade eight bolt and some 5/16 for the handle drilled and tapped for 1/4 set screw I milled a lil flat on the handle and put some locktite to hopefully keep it from moving
    Tozguy, hman, RandyM and 2 others like this.
  29. kd4gij
    kd4gij United States Active User Active Member
    996
    113
    City:
    St. Petersburg
    State:
    Florida
    -Return to Top-
    I always use mild steel for lathe chuck keys. I would rather mess op the key than the socket.
    bobshobby likes this.
  30. scwhite
    210
    43
    City:
    Shreveport
    State:
    Louisiana
    -Return to Top-
    It looks good
    umahunter likes this.
Share This Page
