Your ideas for a shop made O/A hand truck?
erikmannie
H-M Platinum Supporter
Sep 8, 2019
4,392
I have a gas welding cart. I will post pictures of it below. It is great, but I am going to buy an extra acetylene as well as oxygen cylinder, and I want to make a dual cylinder hand truck.
This will be nice for me because I will wheel the hand truck to the side yard, as I never use O/A inside the shop.
There is no need to cart *all* of the brazing, welding, and cutting accessories with me because I am only doing one process at a time.
I want to make such a hand truck from scratch. Do you guys have any ideas for this?
All I need it to do is safely & securely hold the 2 cylinders. That is, I do not require it to hold any equipment such as hoses, torches, goggles, etc.
So all 4 cylinders at the same time?
No, the “dual cylinder O/A hand truck” that I am going to build will hold one acetylene cylinder and one oxygen cylinder, the exact sizes of which are shown in the photos above.
I know that I can buy one of these, but what fun would that be?
One inch thin wall square tubing is what I would use and since there's no need for extra compartments /storage, a (T) shape dolly with a tray on the end (to hold the two bottles) is all you need really, I would use bigger diameter wheels like 8"-10" and also I would weld a piece of angle iron near the bottom so you could put your foot against it to tilt the dolly on the two wheels, makes moving it a bit easier.
For what you describe I'd probably start with a good heavy duty hand truck and modify to your needs. It will probably be cheaper to start with a hand truck than fabricating the whole thing from scratch. Agree with Den-Den on the large tires.
Make sure you have a way to secure it at both the storage and use locations.
Something like this to start with, the wheels alone could cost you $40-100 so at least half the material cost is covered when buying the hand truck.
Milwaukee 800lb hand truck
Mine: oxy-acetylene cart. I call it a "cart", but it's more like a hand truck.
That video is pretty much what I had in mind for my project. Do you mind if I copy your idea, modifying it for my needs?
Were there any changes that you wish you would have made after using this O/A cart?
I would probably use .090” wall tubing & 3/32” stick electrodes (for speed and because SMAW is my favorite welding process).
