i've gota vice that looks very similer, mine has provided good results, what issues did you have with it?
the kurt one does look very very solid
Stuart
stupoty I might have been out of luck with all my vises.
This vise came from ARCEurotrade (UK) and I bought it together with my Sieg X2 mill.
It came with a manual with accuracy tests measurements on it that I suspect are an exact copy in all manuals.
My vise failed miserably in three of the following accuracy tests
G1 0.1
G6 0.1
G8 0.2 on a length of 50mm
As for the rest of the tests I'm not sure I can verify them so I presume they are correct
In plain words that translates as follows.
The body of the vise was not parallel to the base. i.e. when I tested the surfaces on which the jaw moved for parallelism with the base I found that the reading was not equal at the two ends (lower at the far end from fix jaw).
The movable jaw was too loose to hold the work against fixed jaw without a round bar. The main reason for that loosenes was that the movable jaw body was 0.1 thicker and the holding bars had a 0.1 gap between moving jaw and the vise body (the little white area between red and green in the following drawing)
Fixing it was pretty simple!
I made the surface of the body parallel to the base using my fly cutter
and I reduced the thickness of the moving jaw skimming the base of it so there is (virtually) no gap between holding bars and vise body.
BTW
ARCEUROTRADE give them vises away for nearly half price now. If I was in UK I might buy the bigger one (100mm) and fix it.
it is not bad for £46.75 including VAT.
BUT...
I live in Greece and I do not wish to pay another £25 p&p. I don't think is worth it.
Thanks for your interest on the subject
Petros
PS
the KURT-STYLE one looks VERY solid but 16 kilos is far toooooooo heavy for my little x2 mill
