I attempted to heat treat one of the jaws... it was a miserable failure, mostly due to my lack of experience with a torch.
The torch had a brazing tip on it... I discovered the hard way that a brazing tip won't allow enough heat to get a vise jaw hot enough. After realizing this, I let the jaw insert cool, then discovered that it had warped... it had a .030" bow in it.
So... I put it on the 20 ton press to try to straighten it... and broke it...
For the second jaw insert, I put the cutting head on the torch and had it hot enough in about 5 minutes... dropped it in the oil... let it cool... cleaned it... and it had a .015" bow in it.
It was hard... but not straight. I went ahead and finished it, anyway... after grinding it on the surface grinder, (it took .015" from each side to clean it up), it looks ok.
So, this morning, I machined a replacement for the broken one and heat treated it. This time, as I was heating it with the torch, I would flip it over every 30 seconds or so to heat evenly on both sides. This time it only took .004" from both sides to clean it up. I guess I learned something...
Anyway... I'm considering this vise to be finished now...
It's hard to believe this is the same vise that I started with... here is a 'before' and 'after' picture...
I think it turned out ok...
-Bear
