Why are good metric micrometers so hard to find?
Oscar Lazo
Jan 27, 2024
28
I am looking to buy a set of micrometers for hobby machining, and I am trying to work as much in metric as possible. I would like be able to measure parts with more accuracy than I am able to machine them, so I am aiming to get a set of micrometers in the 0-250 mm range and 0.001 mm graduation (0-6'' and 0.0001'' graduation ). However, it seems impossible to find such a set at a reasonable price.
An imperial and mechanical set of 0-6'' and 0.0001'' graduation can be bought on Amazon for something like 120 dollars, but there is no metric equivalent available. Metric versions of these no-name Chinese sets are hard to find, but only at 0.01 mm graduations. Now, it seems to me that since 0.0001'' = 0.00254 mm, it should possible to find metric mechanical sets with at least 0.002 mm graduations. Yet I can only find 0.01 mm, and at that point, I may as well use a good caliper, since it can measure with that accuracy in a wider range and at much lower cost.
Digging further into the more expensive brands (Mitutoyo and Starret) it seems that something similar happens: Mitutoyo's 0-150 mm range set has 0.01 mm graduation, and Starret doesn't make any that are metric. It would seem that my only option is to buy electronic micrometers in the 0-6'' range and change the units. Here's an ilustration of the situation in McMasterCarr's catalogue, but it's like this everywhere I have looked.
Do you know if there are any providers of 0-150 mm mechanical sets with at least 0.002 mm graduation-accuracy?
With a quick Google search I came up with this for the 0 to 25 mm set. I agree, it looks tough to find a reasonable priced set. I guess if you want accuracy you are going to have to pay the big bucks.
Hi Oscar,
It would be interesting if our European members have insight into this. I suspect the underlying reason is that many measuring tools are now digital so no need to have a separate part number for metric, just push the button.
If I wanted a good quality mechanical set I'd be looking at the used market, have you checked eBay?
You may have to piece together a set, but high quality measuring tools are definitely worth the effort.
John
I was looking for mechanical metric sets 0-150 with at least 0.002 graduation, electronic sets are possible to find, but far more expensive as I have seen.
Hi Oscar,
John
Yeah, there are some nice options there, but usually they are only the smaller sizes, and Mitutoyo makes those new. In deed, I am considering buying them piecewise and then making a nice box for them. I thought there should be some providers for the non-US market that is more likely to want metric, but Mitutoyo doesn't make metric sets, being from Japan. Aren't there any European providers? Isn't it odd that there are so many in inches and none in metric? I never had a tool that I could not buy in metric... so why micrometers, of all things! Thanks!
Oscar, being you are in Mexico makes it hard to know what you have available. I got all of my Mics from garage/estate sales (used) all mechanical. Only one came from a friend who gave ma Starrett digit mic.
I don't know what you are working on. My recommendation is if you are working both imperial and metric, for your 2 smallest (0-1" , 1-2") get a digital mic. All others a mechanical. If you deal with large stuff, you can use a caliper for a while. You may need a long reach caliper too.
Once you start making your way around, you'll be able to find what you need, without much guidance from us in the peanut gallery (lots of differing opinions). Whatever you do, get something reliable. If you buy new and find it to be unreliable, or has any issues, return it.
Good tools cost. But some good tools are available for less. Used quality tools in good shape are amazing, especially when gotten for good prices.
Yeah, there are some nice options there, but usually they are only the smaller sizes, and Mitutoyo makes those new. In deed, I am considering buying them piecewise and then making a nice box for them. I thought there should be some providers for the non-US market that is more likely to want metric, but Mitutoyo doesn't make metric sets, being from Japan. Aren't there any European providers? Thanks!
Mit makes metric sets. I lost out on one at a garage sale, someone beat me too it.
Starrett makes several mechanical and electronic metric sets that measure to .001mm. Here are a few mechanical sets.
As for price, nothing with the Starrett name is cheap. The mechanical sets listed above sell for between $938.00 and $2239.00. The electronic sets go for between $1316.00 and $7043.00. Nothing Starrett is built for the hobby market. Everything they make is geared toward the professional.
CME Tools on eBay has a couple sets of inexpensive metric micrometers. Unfortunately, they only go to ,01mm
Keep in mind precision metrology tools have always been expensive. It wasn't until the early 1990's that hobby grade equipment even started to become available. North America used imperial measurements extensively until about that time. Congress attempted to make metric measurements the standard in the US by 1974. There was such a huge backlash a voluntary conversion didn't start until the early 1980's.
While the vast majority of products made in North America are now built with metric dimensions and use metric fasteners most quality measuring tools are still expensive. The manufacturers are still trying to supply the professional market. Once that market is saturated, they'll introduce less expensive models that are more appealing to the hobbyist.
Yeah, I feel like I am very likely to go piecemeal, but I would have liked to get all my mics of the same sort and with a nice box. But yeah, although I'd prefer to skip the bad ones, I am just surprised for the price difference and availability between metric and imperial. I have found metric ones in local sales, but nothing above 50mm. I would like to measure large bores and pistons in the 100-125 mm range.
Ah! I see, so they do make them. But that is close to 3 times my budget. I was hoping someone might know of a provider I missed.
