Which Knee Mill, 3/4 Size?
FYI - I just measured my rockwell and it is 77" from the bottom of the base to the top of the single-phase motor.
Leveling feet, and being able to turn the head probably requires another 3 to 4 inches
unless i was to find a horizontal mill that has the milling head with it that will fit in the garage, it is looking like a Millrite is the path i will be following. I did find one that i was interested in, but it looks like it may have already been sold due to the fact that after several attempts to contact the seller, no response..
I don’t know enough about the horizontal mills to know how tall the milling head is, but having the horizontal capacity would be a big plus to me. There are times I wish I had a horizontal mill, and might get something like the Burke horizontal one of these days.
What is above your garage? If there is a room above, maybe make a housing like on an I/O boat that houses the engine so you can fit a larger mill If you are not single, you will be after doing that!
saw a Hardinge for 1500 bucks
As mentioned by @matthewsx, the attached might be interesting/helpful. Personally, if you could find a used RF45-N2F (that’s the one with power downed) or a Deckel FP2 with an honest quill-type spindle, those would be my choices.
Index model 40? The one I have is currently taken apart to repaint, etc. otherwise I'd take some measurements. I'm 6'4 and I don't believe the top of the motor was much taller than I.
Sent from my Nokia 8 V 5G UW using Tapatalk
To add to the above, the deckel's have both vertical and horizontal spindles. Here is a picture of milling using the horizontal spindle on the Atlas 7B main body. The FP-1 as shown here, doesn't have separate quill on the horizontal, but the bigger models do. I will measure the height on the FP-1, but I can reach over the top of the machine and I'm only 5'8", so it's pretty short in height.
I have a Jet JVM-830 which is close to these Grizzly mills:
Another option is a round or square column mill like these:
I had a round-column mill like the G0760 before buying the Jet mill pictured below. I did decent work on the round column, but found it cumbersome to have to refind X/Y if the head was moved. It did force me to do a better job planning my projects.
The square column mill works much like the knee mill except instead of moving the table up/down to the spindle/head (knee mill), you move the spindle/head to the table. My preference order would be small knee mill (like a Clausing, Rockwell or my Jet) first, then a square column, then a round column. Probably not a big deal, but my Jet has an R-8 spindle so Bridgeport tooling drops right into it. I don't know if the Clausing and Rockwell use R-8 or maybe morse taper?
Precision Matthews offers a few square column mills. There are lots of posts here singing their praises!
Bruce
Jet JVM-830, stands about 6' tall, weighs ~900 lbs. without the vise and tooling.
