- Dec 11, 2014
- 891
Well, I got the back plate and turned down the register to a snug fit. Transferred the hole pattern to plate and drilled and counter bored for M8 socket screws. Screwed the plate to chuck and took to the lathe to check run out. I used a 12mm shaft out of a printer stuck out 2" to test.
No matter where I checked in those 2" or how much I tightened the screws or threaded it on, it always showed around .002 to .004 run out. The only thing I didn't try was drilling the holes the next size bigger for a little more wiggle room, then lightly tighten the screws and check for run out and adjust accordingly.
I just wasn't sure if that was a good idea or if the chuck would loosen up and I'd be back to square one again.
Any ideas on how to get it trued up?
