Balance constant loads with our selection of tool balancers, load balancers, and springs balancers from Endo and Hubbel-Gleason! Browse our full collection at Ergonomic Partners.
www.ergonomicpartners.com
I'm thinking like this. Forgive the artistry "skills". You could mount it on an overhead trolley as well for greater positioning freedom.
OK - so using one of these spring balancers instead of a counterweight effectively halves the load on the overhead support. That's good!
If what it holds up is the centre of the
@rabler style (say wooden) beam, and the two short straps going to the straight edge hang from that, set apart by approximately the Bessel distance, it can still be moved about at will.
The straight edge tool can be raised or lowered at as needed, and when let go, it stays put, as if gravity is cancelled.
Length-ways, it can be tilted either end up, though when actually working, it would be horizontal.
It can be rocked on it's axis, but again, normally sat with measure face downward.
I do like this!
There remains the little plan to have end support rests to set it down on between spotting, or hold it somehow, turned over, the better to be cleaning off, wiping, and laying on blue ink with the brayer roller. I am not sure one wants to be inking it from underneath - upside down.
Thanks very much for the suggestion!
