With that the value proposition goes up a lot for me.A set-tru style one can adjust the TIR down to typically under 0.0004", and it should repeat within this range when you switch out the stock. The tolerance also should repeat within the scroll range,
I have found myself flipping parts a lot on my Atlas 618 so I would like something on my PM-1236T that is as easy to use as a scroll 3 jaw but still hold good tolerances when I flip parts.
I did lookup a toolmex 6" 3 jaw adjustable, I think they were around $1300... so the PM one for $700 seems like a good deal, and for $50 you can get an extra set of jaws. PM also states it's precision balanced, I would think that is of benefit, especially for a smaller weight PM-1236T lathe (big for me though)
Excuse my ignorance... but single scroll pinion just means there's only one spot on the circumference of the chuck to use the chuck key to clamp it down?My 3J 6" scroll is a PBA Setrite with a single scroll pinion and it repeats very well.
And, am I right, on these adjustable chucks, the way you indicate it in for less TIR, unlike a 4 jaw where you adjust each jaw independently, but rather use some screws on the face of the jaw to move it around? That's the impression I got by watching a tubalcain video. So, given the repeatability of an adjustable 3 jaw after you indicate it in, it's set it and forget it.... assuming it doesn't shift out of place.
