- Mar 26, 2018
- 2,719
MTVOR tool holders use a TNMC style insert. These can be purchased either with a threading tip (most common) or a range of square grooves, o ring grooves, and some other oddities. They are fairly strong since they are on-edge and have 3 cutting surfaces per insert.
A ground HSS tool would be good for a one-off or few-off, but this is more realistic for larger runs since you won't need to adjust the tool position for sharpening.
Carbide Insert TNMC 43 NGR .125 TNT, Carbide Grooving Insert, Nordic Carbide, NOS USA Carbide Mfr, Triangle, 1/2" iC x 3/16" T x 13/64" H - 10 pcs.Default Title
Carbide Insert TNMC 43 NGR .125 TNT Carbide Grooving Insert 1 Pack of 10 inserts Made in USA, new old stock. T - Triangle N - 0º Relief Angle M - Tolerance Class +/- .002 to +/- .010 +/- .005 C - Hole: With; Shape of Hole: partly cylindrical hole, 70-90º countersink; Chipbreaker: without...
www.rayjoncarbidetools.com
