- Jan 22, 2011
- 8,016
One aspect of taper turning between centers that is often overlooked is the problem of 60 degree center holes and 60 degree centers. Once you leave spindle centerline, all the angles that were correct while on spindle center are now wrong, and no longer symmetrical with the spindle axis. Some people use spherical centers to combat this problem. There are bell shaped center drills that make up for small angular differences that allows the use of standard center, but not usually enough for steep tapers.
Also, when dialing in a taper with an indicator and a straight reference bar, be sure the indicator is as close to center height as possible so you don't introduce errors. Same when using an existing tapered part such as Morse drill shank to indicate your offset. Make sure the indicator's plunger is parallel with the cross-slide ways. Otherwise you will introduce sine errors.
