First, Happy Thanksgiving to All!
Second, thanks for the links... I didn't know there was a 4x6 band saw group on Yahoo.
Third, I started assembling the band saw today, and learned immediately that one should not rely on the assembly instructions. They never mention the braces for the four legs at all. But worst, they emphasize that you must, Must, MUST place the bottom casting of the saw mechanism itself inside the top of the sheet metal base, and then thread the six screws into the six threaded holes in the casting. With my wife's help (she is amazing; she helped me carry the boxed saw up the steps from the garage, then helped me finagle it onto the base!), we placed the cast portion on the sheet metal base but couldn't get it inside the sheet metal. Take a tape measure to the width, and the inside of the sheet metal base is 6 1/8 inches wide, while the outside dimensions of the casting are 7 inches wide! "jawdrop: AND the holes in the casting are not threaded, but are clearance holes for the bolts. Which explains why nuts were supplied with the bolts. A sweaty half hour later and the casting was bolted to the sheet metal with the casting on the outside, which is how the photo on the box shows it anyway.
So if you are assembling one of these, consider the instructions as "possible suggestions" rather than "instructions"... I'd like the meet the author... :*****slap2:
Thanks to all,
Charlie
Thanks to all,
Charlie
