Had a great Christmas with our kids. Santa left me a few things under the tree. Also picked up some stuff off eBay to fill in the gaps.
Bruce
Santa is getting me an auto-switching control box for my Tormach 1100, currently back ordered from Millfast Products. The Tormach controller has one accessory plug, so the passive probe and electronic tool setter get plugged/unplugged depending on what I'm doing. A minor inconvenience, but what makes it a real pain is the probe and ETS have NO and NC switches. So not only do you have to swap cables, you have to go to a Settings screen to select the appropriate tool. The Millfast adapter lets both the ETS and the Probe be plugged in at the same time, so no more swapping cables and playing with the Settings screen.
Our son got me a set of Dremel tool bits, sanding drums, etc.
Wife got me a spring scale and another block and tackle for the shop. I usually shoot one or two deer a year. This year shot two bucks 20 minutes apart. The shop has two eye bolts in the ceiling, but just one block and tackle. I usually hoist one up with the B&T, then loop a second rope through the eye bolt and tie that off to the deer and a cleat on the wall. Loosen the B&T and move it to the other eye bolt. The second B&T will make things a little easier if I have two hanging. Plus we can check the weight.
Santa also got me a punch holder
My stocking had an Indicol holder for a DTI. I already have one for my Bridgeport and Jet mill, but 15 feet is a bit of a walk . . .
Support bracket and post for a Foredom or Dremel tool grinder.
Optivisor for seeing the splinters I need to dig out of my fingers . . .
My stocking had individual plugs for my Tormach's SMW fixture plate. I have sheet ones that are about 5" x 10", but sometimes have some space between. They sell them in colors or black. Chose the colored ones as they'll be easy to spot on the black fixture plate.
My stocking also had a couple of spiral flute bottoming taps so now I have this style in English sizes from 4-40 to 1/2-13
Wife got me a 4th axis homing kit for my Tormach. I think it's just a Hall-effect pick up like on Tach's guys stick on lathes and mills. This will help for setting up the programmable rotary table.
Santa also brought me a set of ten 1" x 6" soft jaws for the Glacern vises on my Tormach.
5-gallon pail adapter for a shop vac. This goes on the pail and is between the shop vac and suction hose. The idea is the heavy chips and such get dumped in the pail which is a lot quicker to dump than my 16-gallon shop vac
My wife also got me a set of ER32 collets
Daughter got me a pair of Midwest upright aviator snips. I have a similar set that are offset by about a 45. They work much better than standard snips, have an offset that makes them close to a Beverly shear
eBay pick up by me, a bunch of 1/2" Loc Line coolant hoses, valves, nozzles, T's and Y's.
1/4" Loc Line stuff form the same seller.
