What Did You Buy Today?
If you’re going to engrave, check out Stevohdee’s series; I stopped watching after the first couple because he’s too good free-handing:
Even his bad engraving is a thousand times better than what I can get... I will give it a try... just to say I did it... but knowing me, I need the templates, lol.
I normally don't post over here because most of the stuff I buy is just what everyone else purchases (or of lesser quality, so I'm usually a bit on the humbler side of the purchase). But this time, it was too valuable to pass up ($11).
I was watching a woodworking video (talking about using 1-2-3 blocks for wood working setups), and the narrator mentioned 1-2-3 block set up hardware. Heretofore, I've used the threads in the 1-2-3 blocks, or bolts all the way through the blocks, to do my set ups. These little kits are pretty nifty.
The barrel nuts slide right in (some issue with size interference on some 1-2-3 blocks), and have a slot on the side to align the nuts. Then you just thread things together.
Makes setups without protruding bolts or nuts very easy.
Granted, this would be an easy thing to make for yourself, but I had to go make a purchase of them just because the brilliance behind the kit.
Assuming it's not against the policy for this thread, you should share the link to where you got these.
I am low on cold rolled bar stock.
The 2.5” OD is 12L14, the other is 1018.
Steel is getting expensive!!
120 bucks delivered Aloris 3/4" boring bars with inserts, and Aloris Acme threading blades. I have got to get an Acme thread gauge, I have no idea what they fit, but there are blades 3-4-5-6-6-7-8-10-12, and all new looking, I already have the holder, and the boring facing head.
I believe those blades fit -8 series aloris tools, for example mine is a CXA-8. I am not positive but pretty sure these blades fit all the series, AXA, BXA, CXA,CA, and so on.
Edited to add, this one is not mine, I copied it off of the bay. #4 and #6 are the most common.
You probably have enough acme threading tools to last 20 lifetimes. I've had a #6 tool and holder like the one pictured by eyerelief for many years. I've cut well over 1,000 threads with it and only had to cut it down about 1/4". I think the single tool will last me the rest of my life, and I use it on a regular basis.
