What Did You Buy Today?
More "stuff" I don't really need, but. . .
The first is a grinder stand/fixture, from Sears. I hava a homade version on a (slow) wet wheel grinder. This thing looks like it will work on a high speed grinder. Cheaply made (aluminium) but a Craftsman so plausable. I'll try it out once I find the instruction sheet.
The other is a questionable bulk buy of "ship augers", wood bits. My father called them ship augers so I do too. There are over a hundred in all, some in pretty good shape, some in sore need of TLC, and some just down right questionable. I have a good supply of the "normal" sizes already, but the starting price was good and I didn't bid $0.50 over the asking price. Some things you just don't want to see go out as scrap iron. Brings to mind what a fellow thought of an expandable drill for doing locksets. The best he could come up with was a can opener. . .
those grinding jigs work nice for chisels and plane blades on a slow speed wet stone.
Over the past few years, I've built a couple of benches out of hardwood and various species of mystery wood. The thing they had in common was slabby, thick pieces. I wanted to experience a hand build (no power tools) of this type of bench. I put together one unit for my Atlas 10" lathe and another was a combination Nicholson/Roubo style wood working bench. Last thing to do is flatten that with a scrub plane and then finish flat.
Point being, I used the augers with a hand brace like in your photos. My immediate observation was, holy crap, I've never drilled such a perfect hole. My second observation was, holy crap, this is a lot of work. The combination of the two made for an extremely satisfying experience.
edit: I should add, that the augers are fine to use so long as they are straight and not bent. And they are fairly easy to sharpen - another satisfying experience.
Any chance you took photos of that bench for the Atlas? If you did, share them!
Here is a photo album for the wood working bench...
Forgot about this bench for the Atlas Mill...
And after searching...realizing I don't have any real good photos of the Atlas lathe bench build. I'll have to add more to this album sometime...
Bryan, you a leftie too? Damn you worked hard ripping that slab with a short crosscut saw.
Nice work... :)
Some real nice work there.
Growing up that manual tools was all I had. You learn a healthy dose of respect for our forefathers and what they produced with simple tools. Had a set of bits and brace. Was my fathers, but someone else took a liking to it. Would love to have another set. They sure have become expensive these days. Especially when they add the term "Vintage" or "Collectable". Makes me feel old.
I agree.
I was doing a lot of woodworking before machinist equip came in. I find I can do very accurate work with hand tools. I knife all my cuts, and my saw follows it. Of course I am not talking a bench, but fine work. A hand router. I have a cheap dovetail machine, used it once.. from then on all my dovetails were cut by hand. I am not in a rush, and love showing off hand made dovetails. And there are dovetails that a router (electric) won't cut.
Big honking ones.
Being a machinist has upped my woodworking. I do somethings differently, and I appreciate both.. But wood has a beauty that metal doesn't usually...
Some of my augers have been "bowed", not bent, they just don't run true. Especially those that have been cut down for use in a power drill. A lot of "old work" on old houses where the augers do better than paddle bits. I have trued some on a bench, it's not all that hard. Easier than trueing a shaft. The biggest problem with old work is when the auger hits a nail. The spur is as, or more, important than the cutting edge and usually takes the brunt of a nail. The 5/8" auger is usually what I use for electrical work. The gimlet can be reshaped if the time is taken. And lots of patience. . . Those 4 inch files are useful for more than just model building. . .
I wish I had had time to do fine woodwork. Just like with machine work, when I make something, it's because I need it NOW. No time to do a pretty job. I keep telling myself that "someday" I'll build some fancy wood toolboxes. Lots of wood (red oak, mahogany, ebony, walnut) flooring that can be milled down to make the parts. When I am no longer, at least Wife does occasional woodwork too, so the piles out in the barn don't become more firewood. That's the reality of the situation, much as I dislike it.
also for old work, the wood gets harder. Old wood was harder to begin with, because of the number of rings, but the lignum definitely hardens quite a bit over time.
Got these at an estate sale this morning just down the road. Paid $30 for both.
Not sure if I want to keep the intake/carb or not. I only have one engine with a carb and it's a 454. This carb is only a 650 so not really big enough.
