@slodat
You've got me curious again.
In your picture showing the disc sander, please identify the white radiused "L" pieces hanging on the pegboard.
I assume they're templates for cutting/sanding corner radii but I've never seen those.
I googled what I thought (guessed) I could read but no luck.
Wow. that is a lot of templates. Nice shop BTWThey are router templates used in car audio and interior fabrication. Since I got the cnc router and co2 laser I mostly use them for layout and then draw in CAD and cut on cnc equipment. The arcs are nice for picking up a line off a car for example.
That looks like some serious equipment for resin casting. What do you cast?I used to do a lot of resin casting, but it went into hibernation after I moved (8 years ago). I'm really wanting to get started up again so just got myself a nice 5 gallon pressure pot to replace the cheap 2.5 gallon HF pot I had. It should get here on Tuesday. Now I have to start looking around to find out what the current hotness is for resin supplies, after 8 years I'm a little out of the loop.
@slodat What CNC router do you have?
