Picked up a new toy today. We bought this because we want to bring our sheet metal work in-house to decrease costs, and be able to easily build prototype parts. The die you see in it is for the first project, just getting it set up. Up until now we have been using our hand pumped H frame shop press for this job, that's a lot of hand pressing, normally about 400 pieces per run, both ends, so 800 operations. This is going to make life much easier.
1976 Promecam hydraulic press brake. This is the same as an Amada press brake, Amada built these under license from Promecam.
4 foot, 25 ton.
Almost like new, has seen very little use I think. Has a Tektronix asset tag on it. My son said he never saw it in the shop out there when he worked there, so has most likely has been sitting in a warehouse for several (at least 20) years. Wired it into our RPC and it fired right up.
As much as I hate hydraulic operated machines, I really wanted a hydraulic press brake. They are impossible to jam. A mechanical press brake (or punch press) can be jammed at the bottom of the stroke and they are a PITA to get unstuck. As a press maintenance guy I have had to unstick a number of them over the years, and have the bent pipe wrenches to prove it.
It has a feature that I have never seen before, a micrometer shut height adjustment calibrated in 0.001'' increments that is adjustable independent of the pressure adjustment. That silver knob, center left in the picture attached to the blue box, is a micrometer thimble about 3'' diameter. Operates by a hydraulic servo valve, not exactly sure how that all works. I need to study the hydraulic drawings a bit. We got all of the original documentation and manuals with it.
It originally had some kind of ''servo'' backstop, but that had been removed at some point, but some of the controls hardware is still there (antique electronics, circa 1976). So I have been tasked with building a new servo backstop and converting the entire machine into a full on CNC press brake. The good news is that my current project is crated and ready for shipping, so I can jump on this one. Then I need to get my CNC plasma operational so we can cut the sheet metal parts to fold up with our new press brake. I'll post a build thread on both of those projects soon.
