Not actually something I bought - this was the result of some horse trading. Not actually a tool, either. More of an in-complete project which completely enamored me when I saw it.
This is a partially completed 1/4 scale 270ci Offy motor, built following Ron Colanna's book, "Building the 1/4 Scale 270 Offy: A Workshop Manual"
This is probably 80-90% complete as far as the machining goes. What's left as far as I can tell at this time is the ignition, induction and exhaust systems. The machining appeared (to me) mind-boggling to execute as I read through the shop manual. A little research on the name on envelopes and invoices in the tub that this came in gave me some clue as to it's history. A local gentleman who, according to his obituary, was primarily a woodworker by hobby and moved to metal work later in life, built this just a few miles from me, around 2012, when he was 83 years old. He passed at 93.
The tub was filled with the major components, roughly 100 pill bottles full of small parts, special tooling he made for the project, including a miniature valve spring compressor, assorted mandrels, and many other parts and pieces - some of which came from other ICE projects. Block, pistons and head are 6061 alum, rods are 4140 with silver bearings, crank and cylinder sleeves are 1144SP, cams are O1 tool steel, rings are made from cast iron. No castings are used in this project; everything but fasteners, clips and bearings is made from stock. Valve springs were made from music wire. Valves appear to be 3XX stainless. Many of the outer surfaces were bead blasted to mimic a cast finish.
The motor has some wear on the piston sides, etc., but appears to be from dry running the motor - presumably to check compression or set the cast iron rings?? No sign of combustion on any surfaces however, plus there's no carburation, exhaust or ignition other than some electronic bits and some magneto pars in a pill bottle to get the model to run, yet. Beyond just admiring the sheer cool-factor of this thing, eventually I'd like to try to tackle finishing off the project to the point of getting this running. Sort of a tribute to the original builder, MHRIP.
Not sure if this is the appropriate spot for this. I'll probably put a post in the ICE section too, but for now I just hope you enjoy the pictures as much as I have enjoyed looking this thing over, digging through the tub and discovering the bits and pieces in awe.
