Don't hear the rch term often. : )
I had to look that up. Too dang funny.
Level?
Question. I need to double flare a stainless steel 3/8 tube (0.030 wall thickness). I have tried two flaring tools, the cheap one you can find on Amazon (two bars wing nutted together), and the pliers form. Neither works. What would you folks recommend for double flaring stainless?
joe
I'm curious too. There are lots of supporters and detractors out there. I'm guessing that at a minimum I should grind a bit of back rake and side rake on the top. The side relief is adjustable with the two set screws and end relief is built in. I will say that the finish of the holder is very smooth, but the cap screw holes had crud in them. I couldn't run the cap screw in with an Allen wrench with the short leg in my hand. Ran a tap in and pulled out some shavings.I for one will be more than interested in your report on the Aloris threading tool. I have a couple of them and don't really care for them. In some situations they seem a bit bulky and clumsy. I do use them on occasions, but much prefer the standard HSS tool ground to a 60* point. Maybe it's just an old dog and a new trick syndrome.
