- Jan 4, 2021
- 2,702
Don't you mean a cold water heater? If it's already hot, why heat it?A new hot water heater .
OK. Now you've done it.Don't you mean a cold water heater? If it's already hot, why heat it?
The Mechanical Engineers where I managed design projects referred to them as "Water Heaters," which would apply to cold/warm/or not hot enough incoming water.OK. Now you've done it.
The heat pump here pre-heats the domestic water, that feeds the _____ water heater. Is it a hot water heater, or cold water heater if it's staring with already hot water? Where do we transition from Cold to Hot water? Do the initial conditions matter? 45 degree well water vs 70 degree well water? SO...MANY...QUESTIONS...
This conundrum of epic proportions may ruin my day!
And since you didn’t specify what temperature scale, lets use Kelvin to make that question really esoteric.OK. Now you've done it.
Why not Rankine scale? Isn't BTU/Lbs the standard to measure heating of water, we should at least stick with English units...And since you didn’t specify what temperature scale, lets use Kelvin to make that question really esoteric.
Apparently I never shared this eBay score. But posts on an old thread of mine brought it back to front of mind.
I had grand plans to build one of these but projects 1 through 41 seem to always be in the way.
The need subsided when I found this on eBay for $80.
I agree. They also have a wide array of other brilliant products for workpiece holding etc.
If I was rich, I’d give Albrecht a go. Now the only thing I can afford from them, is the catalog
