@WobblyHand
I think it's foolish not to refer the problem back to your supplier (McMaster).
Why? Because informing them of the second defective unit should elevate the problem and facilitate getting it fixed.
By not reporting it to McMaster, they only know of one bad part (from you) and they may dismiss the issue as random.
If McM becomes aware of repeated failures they should purge their stock and resolve it with their supplier.
McM is a top notch performer, with top notch systems in place to handle problems. However, they are not clairvoyant. You need to report the problem.
Once you modify the item, you own it. If you're short of projects, I can probable find some defective crap to sell you.
Similar story: I bought, from McMaster, an arbor for abrasive drums (3" IIRC). It was labeled "Made in USA" and it had unacceptable runout (.08" IIRC). I reported it and they refunded my cost. I didn't want to bother with another POS. I virtually begged them to give me a return label because I wanted some responsible person to see what junk they were passing on. McM didn't want it back. I presume they handled the problem without actually seeing my defective piece. They must have, otherwise they would be going the way of Sears, instead of growing stronger.
